Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
Did you mean:Ā
Axles'
8 REPLIES 8
Message 1 of 9
245 Views, 8 Replies
Axles'
Does Anyone have or know where I can get an i-part for a 6000 lb axle?
I have checked on SDotson's site and there isn't anything there.
Rod
8 REPLIES 8
Message 2 of 9
I have modeled a Spicer 60, 70HD and 80 axle
housing in Inventor 5.3 if that would do you any good (not I parts just
models). The tube axle tube length is easily changed to reflect the
desired flange to flange dimension.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Does
I have
Rod
Message 3 of 9
Yes, please. Please share with us all if you
would?
gcooper
I have
Rod
Message 4 of 9
I will try to post at CF under Spicer Axles but I
don't know what the size limit is so it might not work....these are big files
even zipped.
would?
gcooper
I
Rod
Message 5 of 9
To reduce file size you can move the end-of-part
marker to the top of the browser, then save the file.  If posting to CF is
still a problem, try sending to Charles Bliss and he will post with other
library parts people have contributed.
Hal Gwin
Mechanical
Designer
Xenogen
Message 6 of 9
Yep the file is too big, I will have to have to
send it to Bliss when I get time..sorry.
is still a problem, try sending to Charles Bliss and he will post with other
Hal Gwin
Mechanical
Designer
Xenogen
Message 7 of 9
I work for a trailer axle company, Email me if you don't get what you want and I can see what I can do...jstrang@dexteraxle.com
Message 8 of 9
It's amazing how many BIG companies like Dana
Spicer don't have solids generated of their axles........or maybe they just
say they don't <g>
I
Message 9 of 9
Also amazing those companies running R14...no solids. The reason I make the solids is for dropping into production machinery to make sure everything fits and what not.
