Inventor Forum
Autodesk apperance
5 REPLIES 5
timtower
519 Views, 5 Replies
Autodesk apperance
I hava an problem with my apperance, it is like in the next picture:
Current look
I want it like it is at the installation, with every option seperated. Can somebody help me with this?
Tim,
5 REPLIES 5
mslosar
in reply to: timtower
Try right clicking on or next to the ribbon and choosing 'Ribbon Appearance' from the list and setting it to Normal, or cycle through those options to see if you get the layout you want.
I'm using 2010, and once of my options, 'Compact', did what your image shows, the only difference was that my icons were smaller.
timtower
in reply to: mslosar
My ribbon isnt changing at all, no mather what option i use.
mslosar
What's happening when you click on one of those panels?
There's also an option in the same area for Minimize. If you, for example, minimize it to tiles, it supposed to show just the text and when you click on one you get a drop down list of it's contained commands. Later versions may have more options there, but you could try setting it to Show Full Ribbon.
Outside of that, I don't see any other options. Did it ever work right? I hate to suggest uninstall/reinstall, but it may be the only option.
JDMather
Click here three times (see red arrow in image).
timtower
in reply to: JDMather
Thank both of you for your help, last awnser worked for me.
