Recently I have Installed Autodesk Inventor Proffessional 2013 SP 1.1 Update 2 on few new systems, it is not showing correct Material Appearance (Customised Material). I observed that it is not browsing images from correct folder location.
Following image showing error.
Older systms showing correct appearnace and it takes picture from following location shown in image.
I checked Application Options>File>Design Data (Styles, etc.) for new systems showing correct folder location i.e. From User>Public Documents.
Please let me know, what setting I have to consider to solve above issue.
Thank you.
System: Autodesk Inventor Proffesional 2013 SP 1.1 Update 2
Can you check on the path for your images. Please see the article below for more information.
http://forums.autodesk.com/t5/Autodesk-Inventor/Custom-material-image-Inv-2013/td-p/3596692
