I am having issues saving parts i change, any new ones i create seem to be fine. When i open a file and try to change a part/assembly, a dialogue box shows up saying "part is checked out by another user and/or work space. Cannot save changes unless it is checked out to you." I am signed in to the computer under the name it says the file is checked out under, but i cant figure out how to check a file out. I looked online for help, but I am using Inventor Series 7 and I can't find info on it. I am new to Autodesk and the Vault system, and I'm not sure if i have a Vault Server or Vault Add-in because i can't find any Vault options inside of Autodesk. I noticed the old engineer that had my job before me had the same issues that were never resolved. Any help would be greatly appreciated. Thanks!
Solved by -niels-. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thank you for your quick response, I tried both links and can't figure out how to have it do what i need. Do these utilities only work for unreserving files in the directory, or files inside Inventor? Also, i am logged on as the old engineer, so its saying the files are reserved by me. Any new parts/assemblies I make I can edit and save without a problem, just the old parts/assemblies the previous engineer created wont let me save changes. Inside Inventor, when I go to Projects, under Multi-User it says Shared, not Semi-Isolated.
Welcome to the forum.
Do you have access to the vault client? Do you see a vault tab within your inventor session?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thank you. I do not have any Vault tabs, and when i did a search on my computer for Vault, it brought up these files.
Vaultfiles.settings
assetfiles.settings
vaultlog.cfg
VaultPrefs.dat
Also, when I acces the Add-In Manager, there are no Vault server/Client Add-Ins anywhere.
Niels van der Veer
The Netherlands
Hi Niels,
I'm hoping you can help me too. I get the same check-out to some else's account pop-up, but it's checked out to me ofcourse and I cannot save or alter the file. Now I downloaded the unreserve tool and looked at the status, which then tells me that the files is probably corrupt. Strange beceause I did not do anything to this file, in fact before this issue started appearing, I had already saved a copy as at .stl and 3D pritned it. That was fine. I came back the file, measuring distance on the model and out of habbit wanted to save it over the existing save (for good measure.... see what I did there). And then got this error with the checking-out nonsense. I do not have/use Vaults, there is not activer add-in for it in my version and when searcing my computer I don't even find any of the vault related files mention buy the previous user.
As I have already printed this part, and it is a component of a larger assembly (and I am a total noob and it took me 2 days to make it) I would really like to figure out how to save my file, or copy it to a new place project or something, without having to remake the whole thing. Unfortunately all the copy options when the object is selected are now greyd out.
Any clue what is going on and how to fix/patch/resolve it?
Cheers,
Mila
Niels van der Veer
The Netherlands
Hi Niels,
I can't save or save as copy. I get the following error:
Problems encounted while saving the document ... without any option to expand on the specifics of the error.
Here is my file:
Please don't laugh... that it took me 2 days to make this. (I also made 3 more parts... so it's not quite that pathetic)
Also, thanks for replying so fast! Fantastic!
Looks like an IPJ file instead of an IPT.
New attempt, Mila ..
Walter Holzwarth
Niels van der Veer
The Netherlands
Ok,
So I did that. Went to the OldVersion subforder (who knew it existed, good thinking though) and opened the old version of my document which is from the 17th of March. And apperently at that point in time, I had not mastered extrussion yet, so all I get is the sketch.
How did you guys figure it's not an .ipt? It's called an ipt if I look at the file properties. Or do you mean beased on the code you saw in notepad.
Is there anything to be done? Or is it a lost cause and should just start over from the sketch?
Cheers,
Mila
Actually,
There are two OldVersion folders, One seems to be from the 21st of March. There is a file there which is a .ipt file and I tried opening it but it doesn't allow me to. Error.
Will you try to open it, please ?
P.S. Sorry I had to zip it or it wouldn't uplaod
Niels van der Veer
The Netherlands
This file is the backup of the above Project file, and should be normally named Mold Inventor.ipj.bak
Perhaps the IPT in search is saved to a separate folder. You can try a Windows search for Mold Inventor.ipt, but Windows search is slowly.
Walter
Walter Holzwarth
One more advice:
I think, you have checked your Windows Explorer settings like in the red circle. I recommend unchecking this.
After that you'll see not only a thumbnail, but the filename extension as well.
Walter Holzwarth
Thank you Niels, wh and Walter,
I will remake the part, it shouldn't take me that long this time. Practice does make perfect. Still wish I knew what I did to it to corrupt it, but I guess it will have to remain a mystery.
I also changed the folder settings, thanks for pointing that out.
Cheers,
Mila
