Trying to download Inventor 2015 and keep getting following error message (attached).
Tried restart of computer and download again, same error
Solved by mcgyvr. Go to Solution.
I also had this problem with the 64 bit down-loader but not with the 32bit for some strange reason, don't know why BUT it seem that Autodesk have still done bugger all to fix this problem.
Then the board admin moved the post - I'm still waiting for any replies as to a fix.
The installer.exe is duel 64 and 32 bit ther should be two folders one x64 and the other x86 so IF you can try to down load on a 32bit machine copy the file to at least a 25GB external device and transfer to you 64 bit machine and install as normal.
It's a bit of clart around but it works.
I had the same problem.. I just did the other option to download without that Download Manager software.. Just browser download I believe.
How did you download using without the Autodesk download manager? Please share the steps as I am having trouble downloading Moldflow. Thanks !
