Inventor Forum
AutoDrop not updating
2 REPLIES 2
199 Views, 2 Replies
I've got a simple flange with a hole pattern for which I've got Autodrop putting in the bolts.
In this case 1/4", now if I change the number of holes, everything updates fine.
But if I go into the flange itself and change the size of the threads, say from the 1/4 to 3/8 or whatever and then come back to the assembly and update it, the bolts stay at the original size or the original holes.
Shouldn't they update as well?
2 REPLIES 2
Let me also add that the note dimension/callout in the detail sheet loses it's leader length and can't be adjusted.
We have to delete and re-insert the hole note.
I don't recall seeing this in previous revisions.
BTW - I'm pretty sure I forgot to list, I'm on Inventor 2012 Pro
Above: Showing the original hole size in the flange.
Above: Showing the 1/2" bolt inserted by way of AutoDrop.
Above: Same hole changed to a 3/8" thread
Above: Showing the same assembly after a save and noting the Bolt is still at the original size of 1/2" as opposed to the required 3/8".
Hope all those come in OK.
