I've got a simple flange with a hole pattern for which I've got Autodrop putting in the bolts.
In this case 1/4", now if I change the number of holes, everything updates fine.
But if I go into the flange itself and change the size of the threads, say from the 1/4 to 3/8 or whatever and then come back to the assembly and update it, the bolts stay at the original size or the original holes.
Shouldn't they update as well?
Let me also add that the note dimension/callout in the detail sheet loses it's leader length and can't be adjusted.
We have to delete and re-insert the hole note.
I don't recall seeing this in previous revisions.
BTW - I'm pretty sure I forgot to list, I'm on Inventor 2012 Pro
Above: Showing the original hole size in the flange.
Above: Showing the 1/2" bolt inserted by way of AutoDrop.
Above: Same hole changed to a 3/8" thread
Above: Showing the same assembly after a save and noting the Bolt is still at the original size of 1/2" as opposed to the required 3/8".
Hope all those come in OK.
