Thanks a lot, this is the solution a expected. It works fine !
Thanks again. MiB
"John W. Cargile" wrote in message
news:691A414183D2578C4F579A6ABEA2B7FD@in.WebX.maYIadrTaRb...
> "In-Line Work Features" are work features created in the process of
creating
> a different Work Feature.
> Example:
> You have a part that contains two holes and you want to create a Work
Plane
> that passes through the center axis of these two holes. Instead of
creating
> the two center axes and then creating the Work Plane, all you need to do
is:
> 1. Select the Work Plane Tool
> 2. Immediately, right click and select "Create Axis"
> 3. Pick the first hole.
> 4. Right click again, select "Create Axis" again and then select the
second
> hole.
> A new Work Plane will be created that passes through the two "In-Line"
work
> axes, but the axes "visibility" will be turned ON/OFF based on the setting
> of "Hide In-Line Work Features".
> You will also notice in the Browser, that the two axes are "Consumed" by
the
> new Work Plane.
> Hope this explains it.
> John W. Cargile,
> Inventive Solutions
> "E-Kracht" wrote in message
> news:f145d32.-1@WebX.maYIadrTaRb...
> > What we can do with this option ??? I can't find is meaning....
> > Thanks,
> > E-K
