Inventor Forum
Assembly - part created in place - how to make changes in base part propagate?
2 REPLIES 2
285 Views, 2 Replies
I´m trying to create two parts where the location of holes in the first part controls the location of holes in the second part, and the holes of the second part follow the holes in the first part when those holes are moved.
This is what I did:
1. created Test Part 1 - extruded - added threade holes
2. created assembly
3. Placed Test Part 1 into Assembly
4. Within Assembly Created new part (Test Part 2), with its sketch plane on (the recessed) surface of Test Part 1 in the assembly
5. Extruded (the sketch in test part 2)
6. Added holes to part 2, using projected gerometry originating from Test Part 1
7. Returned to assembly - all looks fine
8. Opened Test Part 1
9. Moved holes of Test Part 1
10. In assembly, the holes on Test Part 1 has moved, but the holes of Test Part 2 has not followed
I´m attaching two part files and an assembly file.
I´m certain I´m overlooking something simple, but I´m stuck... any advice would be much appreciated.
BR,
David
2 REPLIES 2
Hi David,
I think the way you tried to do it should work fine.  I think you may have just projected too many times, and possibly snapped your holes in part 2 to the wrong geometry.  It seemed like you had an extra sketch on Test Part 2, and that the first sketch for the thickness had too many things projected onto it.
I don't know exactly where the issue happened, but I redid Test Part 2, and it seems to work fine.  My method wasn't any different than yours as far as I can tell, so I think it was just some simple mistake somewhere.
Thanks!
I just need to watch how I use projection of geometry, it seems.
BR,
David
