Does anybody know if it is possible to get the assembly name in the title of a partlist.
And then I mean automatically. I know I can type it there 🙂
I don't think there is any way to do that using normal means, but I think I remember seeing an iLogic rule or VBA macro that could do it. I would suggest searching the Inventor Customization forum to see if you can find something like that.
If you mean the assembly name in the title/header of the parts list where the default is "Parts List" then you can simply edit the parts list by using the edit parts list -then parts list table layout and type the assembly name into there.
If you mean as a column in that actual parts list then there is a way
1) Open the subassembly IAM file
a) In the browse pain RMB and select iproperty
b) Click the Customs Tab
c) Type in the new custom iproperty name like "Assembly Name"
d) In the same tab at the bottom add the assembly name and click Modify
You will need to follow these steps for every assembly or subassembly in the final IDW Parts list
2) In the IDW that contains the parts list you wish to customize
a) Either hover over the parts list click LM once when the green dot appear then select Edit Parts List
b) In the Edit Parts List select Column Chooser (left hand most icon)
c) With All Properties showing in the top drop down list click on New Property, this open another sub-section/menu
d) Click where it indicted that opens and enter the NEW property like "Assembly Name" the OK
e) The new property will automatically be placed in the Selected Properties side of the Parts List Column Chooser
f) Kick OK in the Parts List Column Chooser
g) Finally Click Apply
You'll most probably have to do some dragging around of the parts list ands the column widths after all this
Again you will need to follow these steps for every assembly or subassembly in the final IDW Parts list
If it's not possible, this might be a great fit for the Ideas forum for Inventor... ?
Pretty sure I've seen it on there before, actually. I'd suggest doing some searching and vote for the existing idea if you can find one on there. If you can't find it, post your own.
Yeah, I just didn't want to be the type of person that steals an idea and reposts it. I'll take a look this week in case some one posted it or not.
