Inventor Forum
Assembly mass in LOD versus View representation.
6 REPLIES 6
HarryP108
622 Views, 6 Replies
I have read that LOD's should be used only where large assemblies are being worked with - for reasons of computer performance. I occasionally work with assemblies where I require a "Tare" mass and a "Gross" mass.
In this case simply using a View Rep where the visibility of a part or machine is turned off still gives me the Gross mass. ie the mass with the part or machine still in the assembly. Should I be using an LOD or is there a better way?
Regards.
Inventor Professional.
Windows 10.
6 REPLIES 6
blair
in reply to: HarryP108
Use View-Reps as much as possible. There are other aspects as in the IDW environment that use View-Reps and not LOD. As you have mentioned about the Gross-Mass.
LOD is primarily intended as a memory foot-print reduction tool for large assemblies.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
HarryP108
in reply to: blair
Currently use view reps in my idw's.
The view rep, unless I am doing soemthing wrong, does not give me an updated mass when I turn visibility off of some parts. eg gross mass 3500 kg. Turn visibility of slurry pump off - gross mass still 3500 kg. How can I get around this? What am I doing incorrect?
Regards.
Windows 10.
Dennis_Jeffrey
View reps affect visibility, mass is calculated on all components
LOD affects suppression. mass is not calculated on suppressed parts If No is selected during suppression phase. See attached:
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
HarryP108
in reply to: Dennis_Jeffrey
So how would you get around my problem?
Regards.
Windows 10.
Dennis_Jeffrey
I would use the LOD and suppress the parts you do not want to calculate in mass properties. Create a new LOD for this purpose and select the No option for calculations.  Here's a 2012 example & files attached.
HarryP108
As I suspected.
Thank you.
Regards.
Windows 10.
