I make an assembly cut and I want to be able to have it suppressed and unsuppressed in levels of detail. But when I suppress I get "Note: suppressing assembly features will also suppress dependent constraints. Continue?" Is there a way to do this? Applications include making assembly sections for use in drawings, chopping off long columns for a better view, etc.....
Solved by Cadmanto. Go to Solution.
Solved by mrattray. Go to Solution.
The problem I have is that I am unable to have both suppressed and unsuppressed exist as different levels of detail. I have Master, Full length columns, and Cut columns LOD. Cut columns is an assembly cut unsuppressed and Full length columns is the assembly cut suppressed. Trouble if I suppress the assembly cut it is suppressed everywhere (all LOD including the Master) and if I unsuppress the assembly cut it is unsuppressed everywhere (all LOD including the Master). So it seems that I cannot have an assembly cut exist and not exist on different LOD. The assembly cut, of course, is directly above the red X "End of Features" in the tree. Any suggestions?
I second what Mike said. Infact he took the words out of my mouth. As I read your original posting I thought the exact same thing. Why not create an iassembly to show the two variances of the assembly cut.
Great minds think alike I guess!!!
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I guess i-part and i-asm must be the only way to accomplish what I am wanting to do. I have two expert elite users pointing me the same way. I just wish I did not have to get into the whole "i" thing. Thanks
