Hello!
I want to constrain a assembly to work as a gripper. But I can't figure out how.
And I found this Topic that has a solution for it:
http://forums.autodesk.com/t5/Inventor-General/Constraining-a-2-jaw-gripper/m-p/4597337#M487889
But i'm using Inventor 2012 and cannot look at the files. Can someone explain to me how its made?
(mine is attached, img)
/p
Solved by SBix26. Go to Solution.
Solved by JDMather. Go to Solution.
Here's a simple example, in 2012 format.
Sam B
Inventor 2012 Certified Professional
Inventor Professional 2014 SP1 U3
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Coreā¢ i7-3720QM 2.60 GHz; Quadro K4000M
Clever!
@sbixler wrote:Here's a simple example, in 2012 format.
Sam B...
This also works very good, thank you Sir! Very cool!
Clever indeed! š
