A more accurate statement is that these tools are not meant for end users.
Their only purpose is to help developers and QA engineers debug models. If
you use these and screw up your model, you're out of luck.
Loren Jahraus
Autodesk Inventor Workflow Team
"Sean Dotson" wrote in message
news:A0B425B16ABFE997BB2E13BF8AB8E759@in.WebX.maYIadrTaRb...
> I believe that this only gets turned on if you have activated the debug
> toolbars (which are turned on in the registry). Many of these tools are
not
> ready for prime time and can cause problems. Use at your own risk...
> Sean Dotson, PE
> http://www.sdotson.com
> Check the Inventor FAQ for most common questions
> http://www.sdotson.com/faq.html
> "Kim Myers" <---> wrote in message
> news:AC17599C17B46477DB04708582E507AE@in.WebX.maYIadrTaRb...
> > This wasn't in the Registry. I was in Inventor in an .iam file. Right
> click
> > on one of the inserted components and it's the second from the bottom.
> > news:A6F2CBF09986E9C4360FDC5EC85256DD@in.WebX.maYIadrTaRb...
> > > Playing around with the registry I see...Click it and see what
happens.
> > I'd
> > > have a copy of the assembly saved elsewhere however...
> > > Sean Dotson, PE
> > > news:7A7733A20E83D1D01C2BD460B1FD89FC@in.WebX.maYIadrTaRb...
> > > > In an assembly file if you right click on a part, you have an option
> > > called
> > > > Segmentation. What is this? Believe it or not I could not find it
in
> > > Help.
