*sigh*....
Another reason why I should not of upgraded to 2013....
I have an assembly, very simple with only 20 parts max. No components are 'foriegn' (all created within Inventor). I had run a few analysis on it yesterday and everything was good. Today I opened up the assembly and attempedt to go into the FEA and then the program crashes. No warnings or anything.
Using INV 2013 Professional
I cant attach the assembly as it is sensitive data.
I know you mention you cannot upload the assembly to this board but are you able to share the assembly with Autodesk internal people? If so I'd like to see it to see what we can find out. The data would be kept in the US, reduced to the lowest set required to repo the problem, and deleted when unneeded any longer.
Also, did you submit any CER's to the system when you crashed? If so, what e-mail address would have been used? Please mail me separately if you desire.
