Ive just installed Inventor Pro 2015 on a Mac-Book Pro (in a windows 7 32bit environment) 2.2ghz i7, 8gb, Intel HD3000 graphics.
I am going through the tutorials and have run into a quirk.
Tutorial is entitled "navigate the sketch environment"
When I try to extrude any sketch with curves in it it goes crazy, see screenshot...
I have tried with circles with no dimensions, same result. Rectangles, Polygons extrude well.
Any ideas, autocad has no issues on my system normally.
Solved by JDMather. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Hi! It seems like a graphics issue. Could you try changing the following setting and see if it helps?
Go to Tools -> Application Options -> Hardware -> Conservative mode -> OK.
Restart Inventor.
Thanks!
Look here.
