Inventor Forum
Arc Dimentioning Style
2 REPLIES 2
rabbi_ca
250 Views, 2 Replies
Hi Everyone,
well thanks to all arc dimentioning solutions and finally I'm able to draw arc length.
Now there is another problem about the arc dimentioning style.
Can anybody please answer that how can I draw arc dimention just to one end of the arc not all the way round.
Pls check out the image.
Tags (1)
2 REPLIES 2
rhasell
in reply to: rabbi_ca
Hi Rabbi_ca
I will be watching this thread to see what methods are presented.
The method I use is to create a sketch on the geometry to be dimensioned.
Tip:
Create the sketch
If multiple arcs, ensure that they do not lie on top of one another.
Do Not constrain the end points yet, (Only arc center)
Exit Sketch mode.
Dimension the sketched arcs.
Return to the sketch
Constrain the sketch correctly.
Exit sketch.
See my post, to get an idea on detailing arcs.
http://forums.autodesk.com/t5/Autodesk-Inventor/ARC-Length-Issues/m-p/3329175
Reg
2024.2
Please Accept as a solution / Kudos
JDMather
I don't have 2013 installed yet - so I can't answer your question, but just to clear things up for others who might come upon this thread through a search - it has always been possible to dimension arc length through a simple geometric parameter.
The formula for length of arc is well known.
