Inventor Forum
Applying an underscore to dimension text
10 REPLIES 10
Message 1 of 11
1379 Views, 10 Replies
I have a set of dimensions on my drawings however where the dimension is displaying as 6mm in a vertical plane this is quite difficult to distinguish as it could be misread as 9mm. Is there a way to add an underscore mark on the 6 so no mistake can be made as to it being a 6 and not a 9 ? Please see attached screen shot. Thanks
10 REPLIES 10
Message 2 of 11
mrattray
Could you just change to unilateral dimensioning?
Mike (not Matt) Rattray
Message 3 of 11
in reply to: mrattray
Hi, can you please advise on how I would do this by your recommendation. Thanks
Message 4 of 11
mrattray
Message 5 of 11
Thanks yes I saw this, I was just wondering if it was possible to add an underscore to dim text, would be good to see this in the next release Smiley Happy
Message 6 of 11
Curtis_Waguespack
Hi Anthony,
You can do this manually by editing the dimension and adding an underscore to the next line, or use the Straightness symbol as shown.
Then just use the right-click Copy Properties option to add the same to any other dimensions that need it.
Or you could create a style to handle this and then just set the dimensions required to use that style:
I hope this helps.
Curtis
Message 7 of 11
mpatchus
You could create a new text style such as UNDERLINED NOTE TEXT and apply it to the Dimension Style which would result in something like this.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 8 of 11
in reply to: Curtis_Waguespack
This is great, many thanks for all your helpful comments. I guess it really would be most useful when trying to distinguish between the 6 and 9. Cheers
Message 9 of 11
kstate92
In the old days of hand drawings, an underlined dimension was used to state: 'Hey, it was too much work to redraw this entire blueprint, so this feature (while still measuring x) is now supposed to be y.'
But in about ten years, this insight will be about as usefull as being fluent in Sanskrit.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 10 of 11
mrattray
in reply to: kstate92
It's already about as useful as being fluent in Latin...
Smiley Very Happy
Message 11 of 11
SBix26
But don't all (or most) drawing standards specify that text be oriented to read from bottom/right?  I understand that some users may not be familiar with the standards, but there really is no ambiguity once you know the standard.  This seems like a pretty messy way to address a training issue.
