I am trying to get the nearest round number from an expression. However, the round command does not seem to work the way I am expecting it to.
As you can see, I am trying to get "4", but I am getting 3.937008.
Anywone have any idea what is happening here and what I am doing wrong?
I am not sure round(of units) makes logical sense.
Try changing to unitless (ul)
You can use various equation methods to cancel or include units as needed.
Note that your function is shown red (invalid).
Thank you JD
You mentioned some equation methods to make a value unitless.
Where can I find out more about this? I need to make a value (currently in inches) uniltess in order to applay the round command as you instructed.
Hi teunisc,
This thread might help:
http://forums.autodesk.com/t5/Autodesk-Inventor/Parameter-Not-Rounding-Correctly/m-p/4497477#M484997
I hope this helps.
Curtis
one way to cancel unit and add it back on
