Inventor Forum
Anyone know a keyboard command for "square root"?
14 REPLIES 14
Message 1 of 15
CDM369
28193 Views, 14 Replies
I'm trying to write a formula for my parameters and I do not know how to represent a square root symbol.
14 REPLIES 14
Message 2 of 15
in reply to: CDM369
sqrt
Syntax Return Type Expected Type(s)
cos(expr) unitless angle
sin(expr) unitless angle
tan(expr) unitless angle
acos(expr) angle unitless
asin(expr) angle unitless
atan(expr) angle unitless
cosh(expr) unitless angle
sinh(expr) unitless angle
tanh(expr) unitless angle
acosh(expr) angle unitless
asinh(expr) angle unitless
atanh(expr) angle unitless
sqrt(expr) unit^1/2 any
sign(expr) unitless any
Return 0 if negative, 1 if positive
exp(expr) unitless any
Return exponential power (for example: returns 2 for 100, 3 for 1000,
and so on.)
floor(expr) ul ul
Next lowest whole number
ceil(expr) ul ul
Next highest whole number
round(expr) ul ul
Closest whole number
abs(expr) any any
max(expr1;expr2) any any
min(expr1;expr2) any any
ln(expr) unitless unitless
log(expr) unitless unitless
pow(expr1; expr2) unit^expr2 any, and unitless respectively
Can construct unit valid equation that can go invalid "pow(3.0; d12)".
Decimal powers will round at eighth decimal place.
random() unitless unitless
isolate(expr;unit;unit) Mechanical Desktop migration
For more information about using VBA functions for parameters, click this
link:
wrote in message news:5128833@discussion.autodesk.com...
Message 3 of 15
in reply to: CDM369
OR
^.5
Andrew Faix
Product Designer - Inventor Drawing Manager
"RobV" wrote in message
news:5128856@discussion.autodesk.com...
sqrt
and so on.)
floor(expr) ul ul
ceil(expr) ul ul
round(expr) ul ul
abs(expr) any any
link:
Message 4 of 15
CDM369
in reply to: CDM369
thanks much!
Message 5 of 15
in reply to: CDM369
The world can be divided into two types of people.. 😉
Sean Dotson, PE
RND Automation & Engineering
www.RNDautomation.com
www.mcadforums.com
"Andrew Faix (Autodesk)" wrote in message
news:5128877@discussion.autodesk.com...
OR
^.5
Andrew Faix
sqrt
and so on.)
floor(expr) ul ul
ceil(expr) ul ul
round(expr) ul ul
abs(expr) any any
link:
Message 6 of 15
in reply to: CDM369
There are 10 types of people, those who get binary and those that don't.
"Sean Dotson" wrote in message
news:5128894@discussion.autodesk.com...
Sean Dotson, PE
www.mcadforums.com
OR
^.5
Andrew Faix
sqrt
and so on.)
floor(expr) ul ul
ceil(expr) ul ul
round(expr) ul ul
abs(expr) any any
link:
Message 7 of 15
in reply to: CDM369
When I was in college (waaaaay back when) the expression in FORTRAN was
[**0.5]. Is there any language still using this, strictly curiosity.
Ray
OR
^.5
Andrew Faix
sqrt
and so on.)
floor(expr) ul ul
ceil(expr) ul ul
round(expr) ul ul
abs(expr) any any
link:
Message 8 of 15
in reply to: CDM369
FORTRAN still uses it 😉
Sean Dotson, PE
www.mcadforums.com
Message 9 of 15
teunisc
in reply to: CDM369
I am trying to get the nearest round number from an expression. However, the round command does not seem to work the way I am expecting it to.
As you can see, I am trying to get "4", but I am getting 3.937008.
Anywone have any idea what is happening here and what I am doing wrong?
Message 10 of 15
JDMather
in reply to: teunisc
I am not sure round(of units) makes logical sense.
Try changing to unitless (ul)
You can use various equation methods to cancel or include units as needed.
Note that your function is shown red (invalid).
Message 11 of 15
teunisc
in reply to: JDMather
Thank you JD
You mentioned some equation methods to make a value unitless.
Where can I find out more about this? I need to make a value (currently in inches) uniltess in order to applay the round command as you instructed.
Message 12 of 15
Curtis_Waguespack
Message 13 of 15
JDMather
one way to cancel unit and add it back on
Message 14 of 15
teunisc
AWESOME. THANK YOU.
Message 15 of 15
mrattray
FYI... iLogic doesn't care about units even though it uses the same functions.
Mike (not Matt) Rattray
