Inventor Forum
Annotate item in .idw
11 REPLIES 11
Message 1 of 12
588 Views, 11 Replies
Can you annotate an item (sketched symbol for instance) to a line in a
particular view like we could in Desktop?
11 REPLIES 11
Message 2 of 12
SveinE
Select "insert Callout" instead of yust insert
Regards Svein
Message 3 of 12
I'm sorry but I'm not sure what you are talking
about. I don't see "Insert Callout".
Select
Regards Svein
Message 4 of 12
You are right-clicking on the Sketched Symbol and
selecting Insert to place it into the drawing, correct?  Instead,
right-click it and select Insert Callout.
Select
Regards Svein
Message 5 of 12
In the Browser under Sketched Symbols I only have
the following when I right Click. Copy, Delete, Insert, Edit & How To. I'm
running IV6 SP1
Select
Regards Svein
Message 6 of 12
The specific words (+) "Sketched Symbols" are top
level, the individual sketch symbols should be located under that. Should be
able to pick the (+) to show the available symbols, RMB and have Insert
present.
~Larry
running IV6 SP1
and selecting Insert to place it into the drawing, correct?  Instead,
talking about. I don't see "Insert Callout".
Select
Regards
Svein
Message 7 of 12
Right, that is how I insert them now. But if you
look at the reply from DJSpaceMouse he explicitly says "Insert Callout" instead
of Insert. Also if I do just use Insert how is it annotated?
top level, the individual sketch symbols should be located under that. Should
be able to pick the (+) to show the available symbols, RMB and have Insert
present.
~Larry
have the following when I right Click. Copy, Delete, Insert, Edit & How
To. I'm running IV6 SP1
Select
Regards
Svein
Message 8 of 12
Wait up ... that's wrong what I said anyway.
There is a symbol tool in R6 on the tool bar for placing symbols so you can add
a leader, rotate, whatever. By annotated, I suppose you mean filled in with
something appropriate. When you make the sketch symbol you can add fields, same
way you do when you make a title block.
~Larry
instead of Insert. Also if I do just use Insert how is it
annotated?
Should be able to pick the (+) to show the available symbols, RMB and have
Insert present.
~Larry
How To. I'm running IV6 SP1
Symbol and selecting Insert to place it into the drawing, correct?
Instead, right-click it and select Insert Callout.
Select
Regards
Svein
Message 9 of 12
John
Just to clarify. When you say annotate you mean attach to the geometry of
the view (Like MDT's AMANNOTATE) right?
If so people are not realising that R6 changed a bit 😉
To attach symbol to view use the "symbols" command from the drawing
annotation panel. Dbl click your symbol, place it, rmb continue.
To place an unattached symbol use the browser's insert and pick pick pick
There is no more "insert as callout" as every insertion from symbols command
can be a callout simply by dragging a learder from its picked point before
the RMB continue
- Drew
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Corporate: http://www.solidcadcam.com/
Member of the Autodesk Discussion Forum Moderator Program
Visit my MCAD website @ http://www.mymcad.com/
"John Davies" <@> wrote in message
news:CDCA6E62A0997872E7D9815A9A5B7FA5@in.WebX.maYIadrTaRb...
> Right, that is how I insert them now. But if you look at the reply from
DJSpaceMouse he explicitly says "Insert Callout" instead of Insert. Also if
> "Larry Caldwell" wrote in message
news:F4BCF91BADFB7F57DC62ABC5866ED6DD@in.WebX.maYIadrTaRb...
> The specific words (+) "Sketched Symbols" are top level, the individual
sketch symbols should be located under that. Should be able to pick the (+)
to show the available symbols, RMB and have Insert present.
> ~Larry
news:B282C6DA53DABB8B57B5D9BE3507DA9E@in.WebX.maYIadrTaRb...
> In the Browser under Sketched Symbols I only have the following when I
right Click. Copy, Delete, Insert, Edit & How To. I'm running IV6 SP1
> "DJSpaceMouse" wrote in message
news:CE5262C995F4899C563109F896197AEE@in.WebX.maYIadrTaRb...
> You are right-clicking on the Sketched Symbol and selecting Insert
to place it into the drawing, correct? Instead, right-click it and select
Insert Callout.
news:BEDF449C1DF180324E7EC511E55DF5C5@in.WebX.maYIadrTaRb...
> I'm sorry but I'm not sure what you are talking about. I don't see
"Insert Callout".
> "Svein" wrote in message
news:f127692.0@WebX.maYIadrTaRb...
> Regards Svein
Message 10 of 12
Drew,
That's it exactly. It's not quite as good as MDT's Annotate but will work.
Thanks.
"Drew Fulford" wrote in message
news:655A12F6FD7152A24001BE2D587D8D66@in.WebX.maYIadrTaRb...
> John
command
> the RMB continue
> - Drew
if
individual
> > ~Larry
I
> Insert Callout.
see
> "Insert Callout".
> > Regards Svein
Message 11 of 12
Ah, thanks, Drew - I never noticed that change.
command
> the RMB continue
Message 12 of 12
SveinE
Ooops sorry for wrong input.
I knew that.... and it`s not monday either hmmmm....
Regards Svein
