I am currently trying to put together an animation. In the animation I need the camera to move so I use the Add Camera Action command on the Animation Timeline dialog box. To make the camera stationary, I add a camera action, skip a few seconds, then add another camera action without moving the view. After doing this the camera zooms out, I click edit then definition and the zoom is set to 1 deg. To get around this I think I could just move the camera closer to the object, but in the future I would like it if the program worked like the previous versions. I am running Autodesk Inventor Professional 2011 if that helps anyone. Thank you.
To move the camera in two different poisition
Add Camera1 and Camera2 and set camera2 for turntable and camera1 for zoom in and out
Camera1 for target(fixed) to poisition(floating)
Camera2 for Turntable around an axis,workpoint or whatever it may be
post your model
let me try
Are you trying to animate camera positions but not record while the camera moves between positions?
I'm trying to get a sense of what you are trying to achieve. If you can clarify the end goal, perhaps I can be of some assistance. Thanks.
