I am using Inventor Pro 2012. In trying to record an animation, I get 0 byte files. With my IPN file open and tweaked, I hit the animate button. Then I hit record and a save window opens. I accept the default name and hit OK. Then another window opens for resolution settings. As soon as I hit OK the file is saved. I do not get a chance to hit the play button. What am I doing wrong?
Solved by Curtis_Waguespack. Go to Solution.
Hi JeffHobbs6330,
I think this hotfix addresses thes issue you're seeing, but you might check to see if it's included with Service Pack 1 also:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17804829&linkID=9242019
2012 SP1:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17534725&linkID=9242019
All SP's and hotfixes:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019
I hope this helps.
Curtis
