I am still in need of a solution for the Design Accelerator Keyway deficiencies. How do I find out if any progress is being made on this case number?
It 'seems' that there "might" be an 'xml' file somewhere that might table this info, but not certain. Does anyone know if so, where? Filename?
Thanks!
Ken
Hi kjay,
Based on this thread:
I think the XML you're looking for would be located at a location such as this:
C:\Users\Public\Documents\Autodesk\Inventor 20xx\Design Data\Design Accelerator\Tables\
I hope this helps.
Curtis
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
@Curtis_Waguespack wrote:Hi kjay,
I hope this helps.
Curtis
Curtis,
Thanks for the insite. However, upon investigation there are a 'few' apparently applicable 'XML' files. I did some poking about with them and managed to alter some items of interest, but, NOT what needs changing.
In one of the 'keyway' affecting 'XML' files I found an entry (for the shaft size of interest) that equalled the amount that was being used. I changed (corrected) that value, BUT, it changed NOTHING in the creation of the keyway within the D/A.
Other XML files did allow me to 'add' the particular shaft diameter(s) which I wanted to have in the 'pick list' of shaft diameters, but, the keyway information is still eluding me.
Could this information be 'Cast in Brass' within the Registry?
Best regards,
Ken
@Anonymous wrote:
-niels-
Thanks for the input...Please add yourself to the 'thanks' list with Curtis!
Ken
Press the "Kudos" button for each of their posts to give them "thanks"
And don't forget the "Accept as Solution" button either when you get a suitable answer.
