(Sorry for my bad English)
I’m trying to make an iLogic rule that creates a new row in the iPart table (new member). Is it possible?
Any help is appreciated!
Thanks in advanced
Solved by Curtis_Waguespack. Go to Solution.
Hi oztecd,
It is my understanding that you must use the embedded spreadsheet to add a row in an iPart pragmatically, as explained in these links:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Add-iPart-Column/m-p/3792086#M42587
http://adndevblog.typepad.com/manufacturing/2013/02/manipulate-rows-and-columns-of-ipart-1.html
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
Thanks a lot!
Your aid was a great help, Im getting started with API right now, I think it is a very good tool.
