Just add/create a new Material: http://help.autodesk.com/view/INVNTOR/2014/ENU/?contextId=HELP_SYSTEM
epascha,
Here are two more links for you:
Materials
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-15A55781-4AEA-4C34-9060-F25CF02EE3E5...
Create material
http://help.autodesk.com/cloudhelp/2014/ENU/Inventor/files/GUID-0C667C45-2D01-4CAD-9C5A-91E22C2BA474...
Please accept this as a solution if it answers your question.
Have a great weekend.
I don't want to spoil your fun, but modeling Nitinol is tremendously difficult. Typically this is done at the element level (e.g., in ABAQUS) because the material is non-linear and coupled in both strain and temperature, plus it's hysteretic and history-dependant; unless you're going to implement a material model somehow, I don't know what you hope to achieve. By order of magnitude you could assume the martensie phase behaves like copper and the austenite phase like aluminum; but again...you'd be using linear mechanics for a highly non-linear material and your results will be inacurate.
