Unfortunately I have no way of posting anything in R5 format. I would still suggest
looking into Master sketch modeling of one sort or another. There are tutorials at a
number of places
I have on one my site, but you won't be able to open the file, only read the PDF that goes
with it.
http://www.mymcad.com/KWiK/mcad.htm follow the iMaster Link
Sean has one also www.sdotson.com and you can find one here (watch for word wrap)
http://pointa.autodesk.com/local/enu/portal/Articles/process_articles_by_product.jsp?catId
=1&contenttypeId=1&productId=36661
As for your question, I think you would have more luck using a contour flange than a
normal flange. I have personally found adaptivity to touchy and don't use it much, so I
am probably not the best one to answer your questions on it.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Gary_G" wrote in message news:f148f31.1@WebX.maYIadrTaRb...
> Yes... and vise-versa for the 24" side "side 2" which will have it's angle's go inwards
to the 12 X 12 side. Note...all six sides will change making a pyramid shape with the top
cut off... If you notice in my drawing that side's 1 and 2 have flanges with "corner
seams" to allow for this change in angles. With out this it definitely will not work.
> Question??... If I had a sheet metal piece with one edge only having a flange.and I drew
a sketch through it..and I constrained the sketch to the sheet metal ....could I drive the
angle of the flange by changing the angle of the sketch....flange being adaptive of
course.
