Attached assembly contains two column parts and an angle part. Angle part is adaptive and sculpted from planes dragged a distance "0" from the columns' boundaries. Parameters table contains "angle" parameter that determines orientation of angle to columns by way of constraint 'Angle:1." When "angle" is changed from iLogic in a master assembly, angle part will change orientation but will not update its sculpt shape. How may I use sculpt such that the angle part updates when the "angle" parameter is changed?
Hello John
I don't see any rules in the files you attached. Perhaps if you post your code someone will be able to help. Otherwise, I advise you to search for similar posts in this forum.
