Inventor General Discussion
Member
FtnHills
Message 1 of 4 (253 Views)
Actual Physical Texture (not simulated appearance textures)
253 Views, 3 Replies
10-04-2012 07:47 PM
Inventor seems to do lots to allow for simulated appearance textures.   However, how does one use actual physical textures, e.g. for a plastic part?    I need one surface of the plastic part to be very rough/bumpy, another to be slightly rough/bumpy, and another to remain smooth/untouched.
Let me be forthright and say I have no background here in textures/plastics/molds etc., so verbose answers and/or any guidance is much appreciated.
*Expert Elite*
JDMather
Message 2 of 4 (230 Views)
Re: Actual Physical Texture (not simulated appearance textures)
10-05-2012 04:08 AM in reply to: FtnHills
Can't do it.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
FtnHills
Message 3 of 4 (189 Views)
10-09-2012 12:05 AM in reply to: JDMather
Oh, common :smileyindifferent:   How does one use Inventor to build parts that have some texture?  Is there a way to convey texture outside of Inventor?
Related, is there an easy way that one can use Inventor to specify the surface boundaries that will get these canned textures?
*Expert Elite*
JDMather
Message 4 of 4 (179 Views)
10-09-2012 04:28 AM in reply to: FtnHills
What is the manufacturing process to create the texture - perhaps a note will do.
To specify the area of the texture Split faces.
Attach your file here if you can't figure it out.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
