I'm having a brain freeze.
Can somebody please show me how to put an axis through the hole in this sheet metal cone?
Sheet metal file and block part derived from attached and screen capture below.
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Solved by Yijiang.Cai. Go to Solution.
Please consider to create the work axis based on the small cylinder within the base model, then make the work axis derived in derived part.
