Having just modeled a steel tank and placed it into an assembly i wish to change the colour of the part,at present it has inherited its properties from the material, i am sure that to change the colour is a simple process,can anyone point me in the right direction.
Regards
Solved by JDMather. Go to Solution.
Do you want it changed at only the assembly level?
Click the part (in assembly) and select new color.
