Has anyone seen this error message before? I get the message after installing Inventor as a network license.
The steps I take are uninstall everything Autodesk, then Install MDT from the image on the server, and MDT works fine. I then install Inventor from the CD and get this error when I try to start Inventor. This does not happen every time I install Inventor, it may happen every other time or less. I end up having to uninstall IV and installing as a stand alone.
Is there away to fix this with out having to recreate the license file?
Thanks in advance.
Mike
