Inventor Forum
3d sketch points.
6 REPLIES 6
140 Views, 6 Replies
3d sketch points.
In a 3d Sketch.. It would Be So Nice if I could Just Click "Point" and Enter the X,Y&Z coordinates for a Bunch Of points... Then connect the Points with Lines and stuff.
What i'm making is a curved Tube.. & use Sweep to follow the path..
Anyhow.. Maybe there is an Easier way.. 3d Skecthes are kinda foggy to me.. (Rarely use it)..
All I know now is to Make Sketches & work planes and axi with Lines and stuff all over then to attach the 3d sketch point and lines to...
I Know exactly where i want the Points to Go.. It would just be Nice to enter the Coordinates and Place the Points directly.. Without having to Create bunches of Work planes and Stuff...
6 REPLIES 6
Use the grounded work point and click on the center of the ucs icon and
enter your XYZ points click apply and continue on.
wrote in message news:4833202@discussion.autodesk.com...
(Rarely use it)..
All Right..
Thanks... I figured there was some easier way That I just didn't catch.. I rarely Do these... But when i do.
Thanks A Lot.. That works Great..
In Inventor R10, you are allowed to do what you exactly want. Are you on R10
or earlier version?
Johnson Shiue
Test Engineer
(Rarely use it)..
Yeah.. AIS10.. Forgot to mention that..
Be so Nice if there was a Forums were separate for 10, 9, 8 etc..
If you have a lot of points to enter and would like the option of being
able to update their positions, you might consider my addin which reads
point data from an excel spreadsheet, and optionally can adjust the
positions of grounded workpoints by changing the values in the spreadsheet
and re-reading the file in using the addin. Link:
http://www.mcadforums.com/forums/viewtopic.php?t=1942
Bob S
wrote in message news:4833258@discussion.autodesk.com...
I'll check into that..
Thanks..
