I created a pipe run using 1/2 tube. I would now like to change this to 1/4. When I do the tube size stays the same.
http://screencast.com/t/R8HHhtLhmxs
Can someone explain how to get this to change. As you can see in the above video, I am selecting the "Change Size" in the context menu for the hose, but it has not effect.
Solved by blair. Go to Solution.
This is how I do it it T & P with flexible: https://screencast.autodesk.com/main/details/10076373-f181-4640-baaa-d0feb46400f4
Blair,
So you have created a style for each different size tubing? Are those styles stored in each assembly are are they published to a shared library? Would you export one of those so I could see how the style is built?
Kirk
Guys,... the tube & pipe "template" file is "Piping Runs.iam". It is found in your Design Data path... wherever you have put that. Save all T&P styles there to have them available for future use. And yes, you should have one defined for each size of tube or pipe that you want to use.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
