Inventor Forum
2015 Design Suite error
8 REPLIES 8
Message 1 of 9
AvvyD
1123 Views, 8 Replies
I just installed installed Design Suite 2015 last week.
I have installed the service packs.
I have registered.
We run Windows 7.
These programs work just fine:
Autodesk Inventor Professional 2015 - English
Autodesk ReCap
3DS Max
Navisworks Manage 2015
These programs don't open:
AutoCAD Mechanical 2015 - English
AutoCAD Electrical 2015 - English
DWG TrueView 2015 - English
Raster Design 2015 on AutoCAD Mechanical 2015 - English
Raster Design 2015 on AutoCAD Electrical 2015 - English
If I double click the desktop shortcut, or through the start up menu, all pop up with this error:
     "This application was unable to start correctly (0xc0000142). Click OK to close the application."
Our CAD department consists of two people with the same pc setup.  My boss's pc doesn't give this error.  However, some programs are still not loading correctly for him.
Any ideas..?
8 REPLIES 8
Message 2 of 9
barefoothannibal
in reply to: AvvyD
This solved my problem (which was a conflict with Adobe Acrobat 9.5.x Extended Web Capture module)
You can try to change the value to default of 0 in the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\LoadAppInit_DLLs
Credit to technical guru: Osamu Motoyama
Source: http://upandready.typepad.com/up_and_ready/2014/03/autocad-2015-application-error-0xc0000142-autorun...
You can uninstall Adobe Acrobat if you are too timid to edit the registry.
Message 3 of 9
AvvyD
in reply to: barefoothannibal
I uninstalled everything adobe and rebooted.
I am still getting the error.
Message 4 of 9
mcgyvr
in reply to: AvvyD
Uninstalling might not be sufficient..
Run the program autoruns as stated in the upandready link barefoot posted..
Go to the appinit tab and uncheck the box next to anything adobe dll related..
I had the EXACT same problem..and that fixed it.
Message 5 of 9
AvvyD
in reply to: mcgyvr
I don't see anything "Adobe," and I don't know what Bandoo Media is.
Are those what you're referring to?
Message 6 of 9
MingweiGao
in reply to: AvvyD
Hi AvvyD, can you have a try to modify the registry(HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\LoadAppInit_DLLs) to "0" directly?
Steven Gao
Sr. SQA Engineer
Message 7 of 9
kevinhu2010
in reply to: MingweiGao
there are few people encounter the similar issue and solved in this link. could you please have a try? http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2015-0xc0000142-Error-occured/td-p/4919...
Message 8 of 9
AvvyD
Thanks MiniweiGao & barefoothannibal
Editing the registry did the trick. 🙂
Message 9 of 9
ubbogus2
DWG TrueView 2015 - same error - your reply "set to 0 directly" using CMD and REGEDIT worked for me. Thanks
