Were these completely removed from the 2014 version? I used save and replaced often with ground and root component.
Solved by pcrawley. Go to Solution.
Solved by Curtis_Waguespack. Go to Solution.
Hi eman6398,
If you right-click on the ribbon and choose Panels, do you see Productivity listed in the flyout menu? If select it in order to have those tools displayed.
I hope this helps.
Curtis
...and ground & root functionality is available when you use "Place component". Just right-click as you are placing.
Yep, there it is, hiding in the right-click in the ribbon. thanks you guys.
