I am experiencing a significant amount of crashing with Inventor Professional 2014. I have installed the Service Pack 1 and it doesn’t seem to be helping. Typically it is happening when I try and edit an .ipt through an iam. Is this a known issue that others are complaining of?
Attached are my computer specs.
Solved by anderson51. Go to Solution.
Hi anderson51,
If you go to the Tools tab > Application Options > Hardware tab and set it to Performance or Compatibility does that help?
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-F39A7D5F-86E5-4F48-9313-8303E9A799BA
Also, make sure you have the latest service pack and hotfixes installed:
http://knowledge.autodesk.com/support/inventor-products/downloads#?rows=10&sort=score
I hope this helps.
Curtis
Thanks Blair,
When you say change to a User with Admin privileges....are you meaning Windows user?
and of course its always a good suggestion to ensure you are on the latest graphics card driver... Not the Autodesk certified list junk.. The lastest from the cards manufacturers website.
Hi! Did you submit crash reports when Inventor crashed? If yes, please let me know what email address you submit the reports with. Many thanks!
