Inventor Forum
2013 select other menu doesn't pop up and key bindings don't work
1 REPLY 1
Mirfaelltkeinerein
617 Views, 1 Reply
Hi all,
until two weeks ago, I used Inventor 2010, but after a change of our Domain, I had some issues with export and mouse customization (one worked with IV running privileged, but the other didn't and vice versa). Reinstalation didnt solve the problem, so I hoped, that a newer version would solve it. Unfortunately the problems remained the same, but I could get it to work (running mouse software also privileged).
Now I noticed, that the 'select other' menu doesn't pop up, regardless of the delay choosen in the settings. Also some function keys don't work: F7, F8, and F9 don't show any reaction, while all other F-keys work.
Has anybody similar problems? Is there any solution of these problems?
I'm using Inventor Professional 2013, 64 Bit (Build : 200, Release 2013 SP2 Update 2) from our Education Master Suite.
1 REPLY 1
Ok, now (just a few minutes later) I found a solution: running the "Inventor add-in repair utility" solved the issues. I got it from here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13404176&linkID=9242018
