Inventor Forum
2013 - Weird Ordinate dims
3 REPLIES 3
karthur1
279 Views, 3 Replies
Did a copy design and now I am reviewing my idw and correcting the dims.  Came across this part and I noticed that the dimensions were off in space.  What puzzled me is that if they were not connected to geometry, then they should be pink (sick) but they were not.
I tried to slide the dims over and connect it to some geometry, but the dims will not connect.
A hole note on the same part shows the same problem.
I have already corrected one part that did this by deleting it and redimensioning it.  I thought it was just a fluke, then I seen it again in the same idw.
First time that I have seen anything like this in 2013 or any version of Inventor.  I just installed 2013 update 1 also.
Like I said, deleting the view and placing it back on the sheet corrects the problem, but it also takes $time$ to do that.
Here is a video of what I'm seeing.
http://screencast.com/t/elBdbAuTNRB
3 REPLIES 3
Can you share the drawing with us to investigate the issue further.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Here you go.  Refer to the video in the original post to see the issue.
In the same idw, on some of the other parts that have ordinate dims,  try to add a new member to an existing set.  It would not work on some of the parts that I tried it on.
Kirk
Vinod,
Were you able to take a look at the idw?
