Go for a bass reflex (ported enclosure) you have a better chance of a good
sound rather than a flat or booming bass.
Once the sealed enclosure is built it will sound like it sounds.
A bass reflex will be tuneable and at worst you can seal it up.
Or make your sealed enclosure and port it after if your not happy.
There is no comparison in sound IMO but you will have to pick a unit for
bass reflex at the start, a unit specifically for sealed acoustic suspension
enclosures will not be good for a bass reflex.
But if you pick a bass reflex unit it can be used in either, there cheap and
modern cones are quite flexible so your be ok anyway.
If your amp is 100 W RMS get 150 W RMS on the unit.
If your filtering the sub you need more watts than an unfiltered unit, if
your not 20 watts plus and your be deafened by the mid and high frequencies.
A modern 10" unit will go up to 3khz most music is all done at 3.5khz!
Sealed enclosures tune up the speaker not down as in bass reflex.
Filtering the sealed enclosure will be disappointing.
Good luck.
Laurence,
Power is nothing without Control
"Paul Houlker" <666paulh@rimex.com666> wrote in message
news:288B992D60988694D61050F41F07DC9B@in.WebX.maYIadrTaRb...
> That should work ok for the intial design, and when I buy some subs I can
> tweak that speaker model to the correct sizes. I am going with a sealed
box,
> most 10" subs I have looked at require 0.75 cu ft (few are1.0 Cu Ft), so
> again I can just tweak the volume when I make a purchase. Using good old
> MDT6 I already have the box volume to 0.752 Cu ft should be close enough.
> Thanks for the model!
> PS anyone got a tan carpet texture?
