• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    New Member
    origin data within the .stp file visible within the converted .dwg or .dxf file?
    266 Views, 4 Replies
    10-16-2012 11:07 AM
    Is there any hidden data (or text) or embedded orgin data in the .stp file that would be present? If there is any of this data, when the file is converted to either a .dxf or .dwg file, would that hidden data have been converted? I need to make sure that there wouldn't be any of this data present, how can I do that?
    Please use plain text.
    Employee
    Re: origin data within the .stp file visible within the converted .dwg or .dxf f
    10-17-2012 01:00 AM in reply to: tmcmahon
    We will convert all data(including hidden data) to Inventor Fusion and there is no way to hide them automatically. Thank for you requirements, we will consider it in future releases.
    Sincerely,
    Sally
    (Please mark this response as "Accept as Solution" if it answers your question)
    New Member
    10-17-2012 02:13 PM in reply to: SallyYang
    Hello Sally,
    Thank you for assisting me with my issue. Can you tell me how to manually edit any origin data or manually edit any hidden files within the original .STP file so that when I convert it to a .DWG, no origin data is present?
    Secondly, whenever I have looked at a .DXF file or CAD file, there is always a template that shows measurement data, tolerance data, usually a company stamp, and other pertinent data to the drawing. However, in viewing the .STP file, all I see is a 3D image and nothing else. I don’t see any measurements or figures or anything that is usually visible in a standard CAD file. I know that normally the CAD file has all of this data (regardless if it is visible or not), but I don't know if the .STP file is converted to a .DWG file (or .DXF file) that it still has the measurement data. Basically, is there any way to view this data from .STP>.DWG>.DXF?
    Your assistance is appreciated.
    Employee
    10-18-2012 07:58 PM in reply to: tmcmahon
    There is no other way but delete/invisible these hidden objects manually. I apologize for that as it's really cost a lot of time to do these. However, we hope to make some improvement in this area in future releases.
    For second question, I believe the measurement data will be kept.
    Sincerely,
    Sally
    Board Manager
    schneik
    12-05-2012 09:08 PM in reply to: tmcmahon
    I suspect that the DXF files you get are 2D drawings. Most STEP files are 3D parts and assemblies.
    Kevin Schneider
