Inventor Fusion
Message 1 of 3 (245 Views)
only dwg file type?
245 Views, 2 Replies
06-25-2009 09:57 AM
is there a way to save to an ipt? or iam? also (and i know this is a beta type thing, dont mean to expect too much) when i opened an existing ipt none of the original features were available. have i got something set up wrong?
thanks,
Mike
Board Manager
Message 2 of 3 (245 Views)
Re: only dwg file type?
06-25-2009 01:59 PM in reply to: mikew
While you cannot save to an IPT or IAM, you can save to a few other file types besides DWG. Use the "SaveAs" command, and select the desired file type. These other formats only include the geometry, not dimensions, constraints, etc.
Also try the "Find Features" command (first pick the Body1 node in the Browser).
--Jon Balgley (Autodesk)
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Autodesk, Inc.
Employee
Message 3 of 3 (245 Views)
06-26-2009 06:19 AM in reply to: mikew
Just to clarify a bit further. DWG is Fusion's native file format. Fusion can import Inventor ipt and iam files, but that is an import operation only. Because Fusion is not a parametric history-based modeler, it is not able to write full Inventor part or assemblies.
Jeff Strater (Fusion developer)
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
