Inventor Fusion
JDMather
Message 11 of 13 (474 Views)
Re: n00b questions on Inventor Fusion 2013 and .stl files.....
12-08-2012 04:39 AM in reply to: michael.stone
I was able get to a Restore Point created a couple of days ago and that problem is solved.  I will try to get back to your problem on Monday.
It looks like I discovered a serious security problem in Windows.
At work our machines have a program called Deep Freeze that returns the computer as set up by IT each time it is rebooted, so I can safely test things like this.
Turns out if you save even a MS Word *.doc file (can be blank) to the desktop and then rename to *.stl it causes Windows Explorer to go into a failure loop.
Only discovered this because I thought you renamed an stl in order to attach it here since you can't attach stl directly.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Distinguished Mentor
pcrawley
Message 12 of 13 (470 Views)
12-08-2012 12:18 PM in reply to: JDMather
Getting back to the original problem, Fusion is not the tool you want it to be.  As posted earlier, Fusion is a solid modeller, Blender is not.  Blender is a mesh modeller - so if you want "like for like" comparisons, download 3ds max.  That will give you all the push/pull mesh modelling tools you can imagine (and a few more).  It supports STL files too (unlike Windows explorer apparently!)
Peter
Active Member
michael.stone
Message 13 of 13 (463 Views)
12-09-2012 07:11 AM in reply to: pcrawley
Thanks. I'll look into it today.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
