Inventor Fusion
Active Member
michael.stone
Message 1 of 13 (3,064 Views)
n00b questions on Inventor Fusion 2013 and .stl files.....
3064 Views, 12 Replies
12-02-2012 11:25 AM
I'm looking at doing some modeling for 3d printing, and I'm trying to step up from Blender to AutoCAD/Inventor Fusion.
From the Blender perspective, it's easy to import a file (I'm using http://grabcad.com/library/ruger-10-22-bullpup-concept
 ), pick a face/vertex, hit CRTL+L to get all lined faces/vertexes of a sub-part, and then delete/move/copy/whatever.
I can't seem to find the way to accomplish this in Inventor Fusion. It seems to load the STL as a solid that I can't edit. I have tried saving the file as a .dwg and reopen it, but that does not help. (Although I can then open it in AutoCAD, and it causes massive lag trying to just move around and view it.)
So:
How do I edit an imported .stl file?
And how do I take advantage of selecting linked parts/faces?
Thanks!
JDMather
Message 2 of 13 (3,054 Views)
Re: n00b questions on Inventor Fusion 2013 and .stl files.....
12-03-2012 05:19 AM in reply to: michael.stone
I don't know if this works with Fusion or not - but you might check this out
http://labs.autodesk.com/utilities/inventor_mesh
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Board Manager
schneik
Message 3 of 13 (3,033 Views)
12-05-2012 09:01 PM in reply to: michael.stone
Blender is a mesh modeler.  Fusion is a solid modeler, unfortunately it is not so easy to take mesh files like stl and edit them.  They are made up of small triangle chase and don;t have real circles, holes or fillets.
What types of changes are you trying to make and can you post an example stl file so we can help provide suggestions on how you might be able to use Fusion more effectively?
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Active Member
michael.stone
Message 4 of 13 (3,028 Views)
12-06-2012 05:26 AM in reply to: JDMather
Inventor Mesh apparently does not work in Fusion..... I'll have to see about downloading the 30-day trial of Inventor and see if that will work for me.
Active Member
michael.stone
Message 5 of 13 (3,026 Views)
12-06-2012 06:12 AM in reply to: schneik
Kevin,
The website does not accept the .stl extension for uploading, so I’ll attach a .dwg file (I simply opened the .stl, and save it as .dwg.)
I’m trying to work with files for 3d printing, which is why I’m using the .stl format.
As far as changes I’m trying to make….. does “everything” count? One of the projects I am working on is to convert some models for crazy-looking guns in video games into props. (similar to http://www.thinkgeek.com/product/ee47/?srp=4 ) The video game files are in .psk format (skeletal mesh), but the game files contain all possible in-game options (scopes, handles, etc.) and they just make some parts visible or invisible as needed. I’m trying to edit these files to remove the sections I don’t need, and keep the ones I do. (I can't attach an example of the "raw" file with all the parts, it's over the 1.5Mb limit for the website.)
I can do this remove/edit job pretty easily in Blender, but from what I have seen Blender does not handle real world sizing of objects well. I don’t see a way in Blender to say “make this part here 102mm, and scale the rest accordingly.”
This problem is compounded by the fact that I’m going to have to split the model into multiple parts to 3d print. I need exact measurements of pieces to the mm, or I’ll end up printing 3 parts that won’t fit together.
I could do most of my work in Blender if I have to, but at the minimum I’m looking for a way to accurately set the sizing of the model, and then separate the existing pieces with accurate measurements.
Active Member
michael.stone
Message 6 of 13 (3,022 Views)
12-06-2012 08:01 AM in reply to: JDMather
JDMather,
I installed Inventor Pro and the Mesh Enabler. I can open the files, right-click and choose "show mesh edges." That shows me what I'm used to seeing in things like Blender, but I still can't figure out how to select pieces of the mesh. It seems to come through as 1 solid object - uneditable. I can't seem to highlight a subection of the mesh to edit/remove.
Any thoughts? Or am I just missing something obvious? I did say I was a n00b. =)
JDMather
Message 7 of 13 (3,008 Views)
12-06-2012 03:28 PM in reply to: michael.stone
I downloaded the dwg file and renamed to *.stl and it crashed my system (on two computers).
Active Member
michael.stone
Message 8 of 13 (3,002 Views)
12-06-2012 06:17 PM in reply to: JDMather
You should be able to open it as .dwg..... don't rename it to .stl.
JDMather
Message 9 of 13 (2,997 Views)
12-06-2012 09:46 PM in reply to: michael.stone
I mis-read this statement and thought you had renamed an stl as dwg to attach here,
Now I have a very serious problem as the renamed file will not allow my system to run and will not allow me to rename it back to dwg or delete even when starting Windows in Safe Mode. It would be interesting how this is acting like a computer virus if it wasn't my new laptop.  Looks like I might have to do a complete system restore back to original to get rid of this thing,  ouch
Active Member
michael.stone
Message 10 of 13 (2,991 Views)
12-07-2012 01:45 PM in reply to: JDMather
That sounds horrible..... you should be able to delete anything like that from safe mode......
It's not something simple like right-click the file and make sure it's not read only/acrhive, is it? Sometimes it's the little things that get overlooked.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
