• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    Board Manager
    schneik
    Re: inventor fusion mac crashes trying to open saved files
    02-10-2013 08:23 PM in reply to: SallyYang
    We belive the problem is related to using trim is a sketch. We have an update pending with Apple. We will post as soon as we are notified that it is available.
    Kevin Schneider
    Please use plain text.
    Member
    02-10-2013 08:33 PM in reply to: schneik
    That sounds like a correct diagnosis. I've had no trouble since, and I've just made simpler files which have been fine. Thanks, Scott Scott Ferril Rent The Sky Films 952.937.0192 RentTheSky.com
    Board Manager
    schneik
    02-10-2013 08:38 PM in reply to: cbrinke1
    We have a fix submitted to Apple. The issue is trim in sketch.
    Thanks for helping the community with your tip while we figured this out.
    Feel free to send us you thoughts on how Opensccad and fusion compare and any ideas on how we can make Fusion better.
    Kevin Schneider
    Board Manager
    schneik
    Re: inventor fusion Mac crashes trying to open saved files
    02-14-2013 01:05 PM in reply to: schneik
    Apple App Store is updated with a "dot" release that fixes the file corruption issue.
    Older files may not open but if you post here we can try some internal tools to recover data. We apologize for the trouble.
    Kevin Schneider
    New Member
    02-14-2013 01:10 PM in reply to: schneik
    Thanks, the updated version works fine and I was able to open and edit my previously saved model file.
    Member
    02-14-2013 10:26 PM in reply to: schneik
    Wow! So much better!
    New Member
    02-15-2013 12:58 PM in reply to: tbabcock123
    Just updated to version 1.1. Fusion crashed and now it's impossible to open file generated after the update. Older files (created with version 1.0) can still be opened.
    running on a Macbook pro retina 15".   - OSX 10.8.2
    script:
    Launch fusion
    create a new drawing
    save the file
    close fusion
    REopen fusion
    open the file saved previously:
    Some of the objects are missing/not displayed (bodies, etc ) but appear listed in the browser
    After a short while the app crashes.
    None of this happens if I open and save a file generated with older version of fusion.
    Looks like there is file corruption problem when saving/closing newly generated file.
    Plus I noticed this version tends to crash quite often randomly and is far less stable than previous version.
    I know this software is free but if it could be fixed that would be great. Lost several hours of work today.
    Would like to revert to previous version.. can the 2012 version be made available for download ?
    Paul
    New Member
    02-17-2013 02:12 PM in reply to: schneik
    Hi kevin,
    Issue dowsn't like it is fixed (at least for me) unfortunately, please check my previous post for details.
    Fusion 1.1 still fails and crashed when reopening newly created files (after update to 1.1)
    Thank You,
    Paul
    Member
    02-24-2013 12:46 AM in reply to: tbabcock123
