• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    New Member
    inventor fusion mac crashes trying to open saved files
    1610 Views, 49 Replies
    08-16-2012 10:01 AM
    OS: 10.7.4
    RAM: 16 GB ram
    either double clicking the file or calling it from the 'recent files' panel will cause the 'rainbow wheel of death' and the application crashes - makes the application useless.
    Please use plain text.
    Employee
    Re: inventor fusion mac crashes trying to open saved files
    08-16-2012 07:23 PM in reply to: tbabcock123
    Would you please share any simple data that can reproduce this issue with us? We'll do some investigation.
    Macro Liu
    Inventor Fusion QA Team
    (Please make this response as "Accept as Solution" if it answers your question.)
    New Member
    08-16-2012 08:42 PM in reply to: Macro.Liu_Autodesk
    i'm attaching an archive of two files, neither of which i can open (though they were created with my copy of inventor fusion).  they cause the program to crash.
    New Member
    08-19-2012 05:30 AM in reply to: tbabcock123
    The same problem here on a Macbook Pro Retina. The files open fine however on the iMac. Both are running Mountain Lion.
    Employee
    08-19-2012 06:49 PM in reply to: tbabcock123
    Thank you for all the information! We're tracking this issue right now and will try to provide a solution in the future.
    Macro Liu
    Member
    08-20-2012 11:21 PM in reply to: Macro.Liu_Autodesk
    For what it's worth, here is a very simple save file I can't open anymore without crashing. I don't know if it's related, but I was having a really tough time with sketch dimensions that 1) I couldn't select 2) were affecting the constraints of my model anyway. I accidentally saved while I was in this situation and after that, I couldn't open the file.
    Employee
    08-21-2012 01:17 AM in reply to: bentwookie
    Thanks for your sharing! All the information and the dataset are valuable for us to track it down and work out a solution.
    Macro Liu
    New Member
    08-21-2012 08:40 AM in reply to: tbabcock123
    I have experienced the same issue, several times. It seems to happen once fusion crashes while working on the file. Once I close, send error report, reopen fusion, reopen file I was just working on >>> spinning beach-ball crash.
    It seems like the file is somehow corrupted. It even changes the thumbnail preview of the file type on my desktop here  (not working file is on the right)
    I have deleted and reinstalled inventor fusion 3 times, which has not helped.
    OS X 10.7.4 8GB of Ram
    New Member
    08-27-2012 05:04 AM in reply to: jpmurph7
    THNKS FIOR SHARING
    read more about dessert recipes
    New Member
    08-28-2012 04:28 AM in reply to: tbabcock123
    Mine is crashing too, I'm trying to select a surface to draw a line off of.  Actually most commands that I try seem to crash the application now.  Attached is the drawing file and crash report.
    It seems like it's trying to do something graphics related, or at least if I let the spinning beachball of death continue to spin rather than force quit it, that part of the Mac gets hot and the fans start up.
    I'm using a 2011 MacBook Pro 17" model with the Radeon 6750m.  The other system specs are:
    Model Identifier: MacBookPro8,3
    Intel Core i7 2.2ghz
    4GB RAM
    180gb Intel SSD 520
    Let me know if there is anything else that would be helpful for you.
    Edit: Apparently your forums don't allow files with f3d extensions, so when you download OfficeShelf.txt, rename the extension to .f3d to open it.
