Inventor Fusion
New Member
amro.samy93
Message 1 of 7 (2,453 Views)
inventor fusion 2013 Runtime Error! Please repair or reinstall the program.
2453 Views, 6 Replies
06-30-2012 08:23 AM
    We’re sorry, there was an error while initializing the graphics subsystem.  This is likely due to one or more of the following:  your graphics driver is not configured for "True Color", there was a problem installing the application, the application installation was damaged, or some other problem with the graphics hardware and drivers or the configuration of the application.  More detailed information may be included below.
My device is : Dell Inespiron N5110
Processor: Core i7-2670QM CPU @ 2.20 GHz
RAM: 8GB
GPU: NVIDIA GeForce GT 525M     1 GB
HDD: 1TB ,    40GB free of Local Disk (C)
I tried o remove and re-install inventor fusion 2013 and set up DirectX 2009, 2010, 2011 and the problem still apear,  But the Inventor profissional 2013 work better
Thank you
Member
sourabh.roy
Message 2 of 7 (2,356 Views)
Re: inventor fusion 2013 Runtime Error! Please repair or reinstall the program.
07-23-2012 06:26 AM in reply to: amro.samy93
I recently installed Inventor fusion 2013 and I am also facing the same error like you faced.
I am wondering, if you managed to resolve that issue. If yes, could you please share it with me.
Roy
Active Member
lopui
Message 3 of 7 (2,106 Views)
10-15-2012 10:18 AM in reply to: amro.samy93
  • I have the same problem. Have anyone had the solution or direct me to the link to get it resolved?
Board Manager
Phil.E
Message 4 of 7 (2,093 Views)
10-16-2012 09:46 AM in reply to: lopui
See if this helps:
http://forums.autodesk.com/t5/AutoCAD-LT/Display-Driver-not-responding/td-p/3080068
This refers to a different product, but the video card is the same. It's worth a try to just turn off Aero.
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
New Member
kevin.oehler
Message 5 of 7 (863 Views)
09-23-2013 10:36 AM in reply to: amro.samy93
I keep getting a runtime error too ... this just started happening like two weeks ago.
Has anyone found a solution to this yet? I really hope AutoDESK gets a FIX out ASAP.
Board Manager
Phil.E
Message 6 of 7 (859 Views)
09-23-2013 10:43 AM in reply to: kevin.oehler
Thanks for the reply. It sounds like you were running fine until a couple weeks ago. Perhaps there was an update in that time frame?
Go to Start > type in View installed updates, and open the page for installed updates. You should see everything in chronological order. Please let us know what you find.
Phil Eichmiller
New Member
kevin.oehler
Message 7 of 7 (853 Views)
09-23-2013 02:40 PM in reply to: Phil.E
I figured it out, I added a monitor a few weeks ago which somehow enabled a second graphics driver. I guess it changed the default for Inventor because I went to NVIDIA control panel and made the Inventor.exe application file run from an alternative graphics option, and everything seems to work now.
Kevin
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
