• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Inventor Fusion
    New Member
    inventor fusion 2013 Runtime Error! Please repair or reinstall the program.
    1145 Views, 3 Replies
    06-30-2012 08:23 AM
        We’re sorry, there was an error while initializing the graphics subsystem.  This is likely due to one or more of the following:  your graphics driver is not configured for "True Color", there was a problem installing the application, the application installation was damaged, or some other problem with the graphics hardware and drivers or the configuration of the application.  More detailed information may be included below.
    My device is : Dell Inespiron N5110
    Processor: Core i7-2670QM CPU @ 2.20 GHz
    RAM: 8GB
    GPU: NVIDIA GeForce GT 525M     1 GB
    HDD: 1TB ,    40GB free of Local Disk (C)
    I tried o remove and re-install inventor fusion 2013 and set up DirectX 2009, 2010, 2011 and the problem still apear,  But the Inventor profissional 2013 work better
    Thank you
    Please use plain text.
    Member
    Re: inventor fusion 2013 Runtime Error! Please repair or reinstall the program.
    07-23-2012 06:26 AM in reply to: amro.samy93
    I recently installed Inventor fusion 2013 and I am also facing the same error like you faced.
    I am wondering, if you managed to resolve that issue. If yes, could you please share it with me.
    Roy
    Active Member
    10-15-2012 10:18 AM in reply to: amro.samy93
    • I have the same problem. Have anyone had the solution or direct me to the link to get it resolved?
    Employee
    Phil.E
    10-16-2012 09:46 AM in reply to: lopui
    See if this helps:
    http://forums.autodesk.com/t5/AutoCAD-LT/Display-Driver-not-responding/td-p/3080068
    This refers to a different product, but the video card is the same. It's worth a try to just turn off Aero.
    Phil Eichmiller
    Software QA Engineer
    Fusion Quality Assurance Team
