Inventor Fusion
Active Member
greenheron
Message 1 of 13 (437 Views)
how to non-uniform scale with specific dimensions and not ratios
437 Views, 12 Replies
09-04-2013 06:48 PM
I'm moving from Sketchup to Inventor Fusion, and most things I find easier in Fusion (like drilling holes, building advanced shapes, and easier component manipulation). But I'm struggling with one thing, and that involves modifiying shapes in non-linear dimensions. I understand that I can scale non-linearly, but I need to specify specific dimensions for a project.
I created the object below in Sketchup. It's a stack of 1/2" component slices (to be cut on a CNC router) that transition from a large elliptical/oval shape at the bottom to a round shape at the top. To create this shape, I started with the large elliptical bottom piece at one end and pulled the shape up 1/8" and then specified the dimentions (i.e 25.253in, 18.532in) for each of the two axis based on a set of values I calculated in a spreadsheet.  The shape gradually tapers to the circle at the top.
In Fusion, I can only find a way to scale based on a ratio (like 1.5 being 150%) or tweak faces which also references the current size of the face. The problem with either of these methods is that an error would compound steadily through the hundreds of operations. Is there a way to scale from a center point and specify specific dimensions? Or is there a different way to model this?
Thanks in advance for your help!
Board Manager
Phil.E
Message 2 of 13 (418 Views)
Re: how to non-uniform scale with specific dimensions and not ratios
09-10-2013 05:07 PM in reply to: greenheron
Greenheron,
The thing you are trying looks like it would be better done with many separate extrusions.
The workflow is shown in the image below. Let me know if this helps, or mark this with 'accept as solution'.
Thanks!
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Active Member
greenheron
Message 3 of 13 (408 Views)
09-11-2013 06:48 PM in reply to: greenheron
Thanks--that workflow makes sense, but I can't seem to get the Sketch Dimension tool to work consistently with ellipses. It seems to work all right with other shapes (archs, circles, rectangles), but I can't seem to add dimensions to ellipses. Also, in the PDF guide, it appears that dimension boxes should be available when creating the ellipse. They don't seem to be available like they are for all other shapes. I'm using Inventor Fusion and Fusion 360 on a Mac and there doesn't seem to be any difference between the two in how ellipses function.
Any tips?
Board Manager
Phil.E
Message 4 of 13 (400 Views)
09-12-2013 08:59 AM in reply to: greenheron
Thanks for the heads up about the help guide. I'll look into that. And it's pretty cool you are using Inventor Fusion and Fusion 360!
In both Inventor Fusion and Fusion 360 ellipses are dimensionable objects.
Inventor Fusion:
  1. Create the ellipse
  2. Use sketch dimension tool
  3. Select the ellipse
  4. Dimensions will appear
  5. Right click and OK to dismiss the dimension tool
  6. Single left click on each dimension, an edit box will appear
Fusion 360
(Do steps 1-3)
4.1 One sketch dimension appears. Axis is determined by direction of drag.Click to place.
5.1 Dimension tool is still active now. Select the ellipse again, drag to get second axis dimension
6.1 Single left click each dimension to edit the value (while dimension tool is active)
I hope that helps! Feel free to ask more, or just mark Accept as Solution so other users can benefit.
Phil Eichmiller
Active Member
greenheron
Message 5 of 13 (397 Views)
09-12-2013 10:24 AM in reply to: Phil.E
Thanks for the prompt reply, Phil. Dimensions work as you describe with other objects like squares and circles, but I haven't been able to get dimensions to work with ellipses with the steps you describe. Does this have to do with a problem using the software on a Mac? I tried to attache a video of the steps I'm attempting, but the mp4 file format isn't supported on this forum. I spent at least 1/2 hour yesterday experimenting without success. Out of 30+ attempts and hundreds of clicks on the object (axis, center, surface, etc.) with the dimension tool, I only got dimensions to appear twice, but I couldn't replicate exactly how I clicked. Both Fusion 360 and Inventor Fusion seem to function the same in this regard where I can't get dimensions to work consistently with ellipses. Is this a bug in the Mac version or operator error?
Board Manager
Phil.E
Message 6 of 13 (392 Views)
09-12-2013 10:46 AM in reply to: greenheron
Okay, now I realize you are using Inventor Fusion for Mac. There is currently a limitation that prevents dimensioning elipses.
Fusion 360 has no problem with this. It works the same on Mac or Win.
Let's break down the steps for Fusion 360 for extra clarity.
Using Fusion 360
  1. New sketch
  2. Create the ellipse using sketch > elipse tool  [do not create an ellipse by using Offset tool]
  3. Start the sketch dimension tool
  4. Select the ellipse (pick only the curve edge of the ellipse)
  5. Drag some distance
  6. One sketch dimension appears. [Please let me know if you don't see a dimension at this point]
  7. Axis is determined by direction of drag.
  8. Click to place.
  9. Dimension tool is still active now. Select the ellipse again, drag to get second axis dimension
  10. Single left click each dimension to edit the value (while dimension tool is active)
Phil Eichmiller
Active Member
greenheron
Message 7 of 13 (387 Views)
09-12-2013 01:02 PM in reply to: Phil.E
I don't see a dimension at that point on either Fusion 360 or Inventor Fusion.
Board Manager
Phil.E
Message 8 of 13 (384 Views)
09-12-2013 01:45 PM in reply to: greenheron
This is not expected behavior for Fusion 360. I'm going to need more information, sorry for any trouble.
Can you send your machine specs? Mac model and year, OS version, video card info?
Also, can you send me your data and a video of your sketching workflow inside Fusion 360? phil dot eichmiller at autodesk dot com
(If you go to the Fusion menu, pick Export Archive that will make a local copy of your data.)
Phil Eichmiller
Active Member
greenheron
Message 9 of 13 (380 Views)
09-12-2013 06:38 PM in reply to: Phil.E
Video, archive, and specs sent...
Board Manager
Phil.E
Message 10 of 13 (373 Views)
09-13-2013 09:31 AM in reply to: greenheron
Inventor Fusion for Mac has currently has a limitation that prevents dimensioning ellipses.
Can you try again in Fusion 360?
HP EliteBook 8560w Win 7
13" MacBook Pro, mid 2009 OS X 10.8.4
Portland, Oregon
Phil Eichmiller
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
