Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
drawing diagonal 3d shapes
3 REPLIES 3
PARKYNSPACE
2352 Views, 3 Replies
I am fairly new to inventor fusion and have been teaching myself as I go. I am drawing a 3d model of an axle for a cart and cannot figure out how to draw a cylindrical 3d support strut going from the horizontal to vertical axis with a circular cross section. Any help would be appreciated. Andy
3 REPLIES 3
schneik-adsk
in reply to: PARKYNSPACE
Can you post a file or screenshot? It is hard to imagine this with only words.
Kevin Schneider
PARKYNSPACE
in reply to: schneik-adsk
Hi
Please find attached the image of my work so far. The diagonal axle would effectively run along the works axis label in the image (hopefully visible in the image). There would be a flattened tube section  at either end that i can draw as a simple rectangle
JDMather
Can you create a 3-point rectangle (do it line-by-line if you have to) at that angle and then Revolve the rectangle (would be easier than setting up an angled sketch plane)?
